function mtel(tel){
if (tel.length==10) {tel = tel.replace( /(\d{3})(\d{3})(\d{4})/, '0($1) $2 $3' ) }
else {tel = tel.replace( /(\d{3})(\d{4})/, '0(212) $1 $2' )}
return tel}
function siparis(ads){
var ids = sql.Query("SELECT TOP (1) Tickets.Id FROM TicketEntities INNER JOIN Tickets ON TicketEntities.Ticket_Id = Tickets.Id WHERE EntityName in ('"+ads+"') AND Tickets.IsClosed = 1 ORDER BY TicketEntities.Ticket_Id DESC").First;
return sql.Query("SELECT CONCAT('<block 1 transparent left 300>','<block 1 transparent left 30>',CONCAT(FORMAT(Quantity,'#.##'),'x'),'</block><block 1 trasparent left 200>',CONCAT(MenuItemName,CASE WHEN PortionName = 'Normal' THEN NULL Else CONCAT('.',PortionName) END),'</block><block 1 transparent right 70>',Format(Price,'#.00##','TR-tr'),'</block></block>') FROM Orders WHERE TicketId = "+ids+"").Join('<br/>')
function toplam(ads){
return sql.Query("SELECT FORMAT(TotalAmount,'#.00##','TR-tr') FROM Tickets WHERE IsClosed = 1 AND Id = "+ids+"").First}
function count(ads){return sql.Query("SELECT DISTINCT COUNT(Ticket_Id) FROM TicketEntities WHERE EntityName in ('"+ads+"')").First; }
function grand(ads){
var ids = sql.Query("SELECT DISTINCT Ticket_Id FROM TicketEntities WHERE EntityName in ('"+ads+"')").Join(',');
return sql.Query("SET LANGUAGE Turkish SELECT FORMAT(SUM(TotalAmount) , 'C') AS 'Currency Format' FROM Tickets WHERE IsClosed = 1 AND Id IN ("+ids+")").First}
function gun(ads){
var gun = sql.Query("SELECT DATEDIFF(day,Date,GETDATE()) FROM Tickets WHERE IsClosed = 1 AND Id = "+ids+"").First
if(gun==null){var gun = '0'} else {var gun = gun}
return gun}
function tarih(ads){
return sql.Query("SELECT Date FROM Tickets WHERE IsClosed = 1 AND Id = "+ids+"").First}
<block 1 transparent left 400 wrap>
<i>Müşteri </i>: <b>$1</b><br/>
<i>Telefon </i>: {CALL:musteri.mtel('{ENTITY DATA:Telefon}')}<br/>
<i>Adresi </i>: {ENTITY DATA:Adres}<br/>
<i>Bakiye </i>: <color darkred><b>{ENTITY BALANCE} ₺</b></color>
</block>
<block 1 transparent left 350>
<b>Son Siparişi </b> <b>{CALL:musteri.toplam('$1')} ₺</b><br/>
<size 15>{CALL:musteri.siparis('$1')}</size>
</block>
<block 1 transparent left 250>
<b>Sipariş Bilgileri</b><br/>
Sipariş Adedi : <b>{CALL:musteri.count('$1')}</b> Adet<br/>
Sipariş Toplamı : <b>{CALL:musteri.grand('$1')}</b><br/>
Son Sipariş Süre : <b>{CALL:musteri.gun('$1')}</b> gün<br/>
Son Sipariş Tarih: <br/><b>{CALL:musteri.tarih('$1')}</b><br/>
</block>
Müşteri Ara Detay.zip (1.7 KB)
Merhaba.
Müşteri arama bölümünde uygulama olarak çok güzel. Peki caller id ile gelen telefon aramasında direk paket servis bölümüne müşteri seçimi geliyor. Burada benzer bir uygulama yapılabilirmi?
Paket servis de bulunan Detay kısmına
Müşeri ara daki Detay kısmını kopyala yapıştır
<block 1 transparent left 400>
<block 1 transparent left 70><i>Müşteri</i></block>: <block 1 transparent left 320><b>$1</b></block><br/>
<block 1 transparent left 70><i>Telefon</i></block>: <block 1 transparent left 320>{CALL:musteri.mtel('{ENTITY DATA:Telefon}')}</block><br/>
<block 1 transparent left 70><i>Adresi</i></block>: <block 1 transparent left 320 wrap> {ENTITY DATA:Adres}</block><br/>
<block 1 transparent left 70><i>Bakiye</i></block>: <block 1 transparent left 320><color darkred><b>{ENTITY BALANCE} ₺</b></color></block>
</block>
<br/>________________________________________________________________________
<br/>
<block 1 transparent left 360>
<block 1 transparent center 340><b>Sipariş Bilgileri</b></block><br/>
<block 1 transparent left 150>Sipariş Adedi</block>: <block 1 transparent right 190><b>{CALL:musteri.count('$1')}</b> Adet</block><br/>
<block 1 transparent left 150>Sipariş Toplamı</block>: <block 1 transparent right 190><b>{CALL:musteri.grand('$1')}</b></block><br/>
<block 1 transparent left 150>Sipariş Ortalama</block>: <block 1 transparent right 190><b>₺{CALL:musteri.parite('$1')}</b></block><br/>
<block 1 transparent left 150>Son Sipariş Tarih</block>: <block 1 transparent right 190><b>{CALL:musteri.gun('$1')}</b> gün <br/><b>{CALL:musteri.tarih('$1')}</b></block><br/>
</block>
<br/>
<block 1 transparent left 100><b>Son Siparişi </b></block>
<block 1 transparent center 130>#( {CALL:musteri.id('$1')} )</block>
<block 1 transparent right 70><b>₺{CALL:musteri.toplam('$1')}</b></block><br/>
</block>
<block 1 #FFF5F05D left 400><color navy>
<block 1 transparent left 70><i>Telefon</i></block>: <block 1 transparent left 310>{CALL:musteri.mtel('{ENTITY DATA:Telefon}')}</block><br/>
</color></block>
<br/>
<block 1 lightgreen left 400>
<block 1 transparent left 150>Adisyon Adedi</block>: <block 1 transparent right 190><b>{CALL:musteri.count('$1')}</b> Adet</block><br/>
</block>
<br/>
<block 1 skyblue left 400><color darkred>
</color></block>
