Kasa tanımlaması yaparken Gelir Belgesi Tanımlamasında döküman tipini eklerken hata verip programı kapatıyor. Detay
“”[General Info]
Application: SambaPOS
Version: 5.2.3
Region: tr
DB: SQ
Machine: WALKIN01
User: walkin
Date: 12.08.2018
Time: 15:58
User Explanation:
walkin said “”
[Exception Info 1]
Top-level Exception
Type: System.Reflection.TargetInvocationException
Message: Özel durum bir çağırma hedefi tarafından oluşturuldu.
Source: mscorlib
Stack Trace: konum: System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
konum: System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
konum: System.Delegate.DynamicInvokeImpl(Object[] args)
konum: System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
konum: System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception 1
Type: System.Data.Entity.Infrastructure.DbUpdateException
Message: An error occurred while saving entities that do not expose foreign key properties for their relationships. The EntityEntries property will return null because a single entity cannot be identified as the source of the exception. Handling of exceptions while saving can be made easier by exposing foreign key properties in your entity types. See the InnerException for details.
Source: EntityFramework
Stack Trace: konum: System.Data.Entity.Internal.InternalContext.SaveChanges()
konum: System.Data.Entity.Internal.LazyInternalContext.SaveChanges()
konum: Samba.Infrastructure.Data.SqlData.EFWorkspace.CommitChanges()
konum: Samba.Presentation.Common.ModelBase.EntityCollectionViewModelBase2.<.ctor>b__0_3(EventParameters
1 x)
konum: Microsoft.Practices.Prism.Events.EventSubscription1.InvokeAction(Action
1 action, TPayload argument)
konum: Microsoft.Practices.Prism.Events.EventSubscription1.<>c__DisplayClass2.<GetExecutionStrategy>b__0(Object[] arguments) konum: Microsoft.Practices.Prism.Events.EventBase.InternalPublish(Object[] arguments) konum: Microsoft.Practices.Prism.Events.CompositePresentationEvent
1.Publish(TPayload payload)
konum: Samba.Presentation.Services.Common.ExtensionMethods.Publish[TEventsubject](TEventsubject eventArgs, String eventTopic, Action expectedAction)
Inner Exception 2
Type: System.Data.Entity.Core.UpdateException
Message: An error occurred while updating the entries. See the inner exception for details.
Stack Trace: konum: System.Data.Entity.Core.Mapping.Update.Internal.UpdateTranslator.Update()
konum: System.Data.Entity.Core.EntityClient.Internal.EntityAdapter.b__2(UpdateTranslator ut)
konum: System.Data.Entity.Core.EntityClient.Internal.EntityAdapter.Update[T](T noChangesResult, Func2 updateFunction) konum: System.Data.Entity.Core.EntityClient.Internal.EntityAdapter.Update() konum: System.Data.Entity.Core.Objects.ObjectContext.<SaveChangesToStore>b__35() konum: System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func
1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
konum: System.Data.Entity.Core.Objects.ObjectContext.SaveChangesToStore(SaveOptions options, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction)
konum: System.Data.Entity.Core.Objects.ObjectContext.<>c__DisplayClass2a.b__27()
konum: System.Data.Entity.Infrastructure.DbExecutionStrategy.Execute[TResult](Func`1 operation)
konum: System.Data.Entity.Core.Objects.ObjectContext.SaveChangesInternal(SaveOptions options, Boolean executeInExistingTransaction)
konum: System.Data.Entity.Core.Objects.ObjectContext.SaveChanges(SaveOptions options)
Inner Exception 3
Type: System.Data.SqlClient.SqlException
Message: Conversion failed when converting the nvarchar value ‘50AF7328F264_A666_’ to data type int.
Source: .Net SqlClient Data Provider
Stack Trace: konum: System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) konum: System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action
konum: System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
konum: System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
konum: System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
konum: System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
konum: System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) konum: System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource
1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
konum: System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
konum: System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.b__0(DbCommand t, DbCommandInterceptionContext1 c) konum: System.Data.Entity.Infrastructure.Interception.InternalDispatcher
1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func3 operation, TInterceptionContext interceptionContext, Action
3 executing, Action3 executed) konum: System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.NonQuery(DbCommand command, DbCommandInterceptionContext interceptionContext) konum: System.Data.Entity.Internal.InterceptableDbCommand.ExecuteNonQuery() konum: System.Data.Entity.Core.Mapping.Update.Internal.DynamicUpdateCommand.Execute(Dictionary
2 identifierValues, List`1 generatedValues)
[Assembly Info]
mscorlib, Version=4.0.0.0
Samba.Services, Version=1.0.0.0
Samba.Domain, Version=1.0.0.0
Samba.Infrastructure.Data, Version=1.0.0.0
Samba.Presentation.Services, Version=1.0.0.0
System.Core, Version=4.0.0.0
DevExpress.Xpf.LayoutControl.v16.2, Version=16.2.6.0
System.Xml, Version=4.0.0.0
DevExpress.Xpf.Grid.v16.2, Version=16.2.6.0
System, Version=4.0.0.0
DevExpress.Xpf.Grid.v16.2.Core, Version=16.2.6.0
WindowsBase, Version=4.0.0.0
System.Xaml, Version=4.0.0.0
Samba.Infrastructure, Version=1.0.0.0
System.Runtime.Serialization, Version=4.0.0.0
DevExpress.Xpf.Core.v16.2, Version=16.2.6.0
System.Windows.Forms, Version=4.0.0.0
System.Drawing, Version=4.0.0.0
Samba.Persistance, Version=1.0.0.0
Stateless, Version=1.0.0.0
PropertyTools, Version=2012.4.14.1
Samba.Localization, Version=1.0.0.0
ReachFramework, Version=4.0.0.0
EntityFramework, Version=6.0.0.0
FluentValidation, Version=3.4.0.0
Microsoft.CSharp, Version=4.0.0.0
Omu.ValueInjecter, Version=2.3.0.0
DevExpress.Data.v16.2, Version=16.2.6.0
WindowsInput, Version=1.0.4.0
[System Info]
Operating System
-Microsoft Windows 10 Pro
–CodeSet = 1254
–CSDVersion =
–CurrentTimeZone = 180
–FreePhysicalMemory = 1594716
–OSArchitecture = 64 bit
–OSLanguage = 1055
–ServicePackMajorVersion = 0
–ServicePackMinorVersion = 0
–Version = 10.0.17134
Machine
-WALKIN01
–Manufacturer = RealBom
–Model = RB-P101G
–TotalPhysicalMemory = 4181983232
–UserName = WALKIN01\walkin
